Gaskets with "The Right Stuff" or just "Right Stuff"
Old Nov 13, 2016 | 09:48 AM
chad.taylor.fsu's Avatar
Default Gaskets with "The Right Stuff" or just "Right Stuff"
I was able to locate all the leaks on my motor so I will be replacing the gaskets on the front cover, gear cover, side cover, oil cooler, transmission pan and power steering gasket. I have seen that alot of people recommend "The Right Stuff" but I wanted to know if i should use it with replacement gaskets or by itself? If I use it with the gaskets do I put the sealant on the gasket and let it set for a day or straight on the metal and let it set for a day? Thanks for the help.
Old Nov 30, 2016 | 08:38 AM
HDP_12v's Avatar
If it was me i would go with the original gasket but when putting a dab of the right stuff on the corners but i would go with the gaskets. Thats just me because of you dont let it sit anf cure right it will leak.
-Hope its some help
