04.5 engine light coming on. lose power
Old Oct 16, 2016 | 01:31 PM
fillme's Avatar
Default 04.5 engine light coming on. lose power
I have a 5.9. Can't reset p2149 & p 2607 truck runs good until 200 degrees. Engine light comes on runs on only 3 piston.
Old Oct 16, 2016 | 04:05 PM
CumminsCoalRoller24/7's Avatar
P2149 Fuel Injector Group 2 Supply Voltage CircuiT
http://www.cumminsforum.com/forum/3rd-gen-non-powertrain/92542-p2607-engine-light.html#/topics/92542?_k=8bhnkl
Symptoms make sense for these codes. Check grid heater solenoid wiring/connections and clear codes. Check your coolant level also- how quick does it get to 200?
Old Oct 16, 2016 | 10:05 PM
fillme's Avatar
Can't clear Codes. Tried the button on dash and tried taking cables off battery. Replaced both the injectors and injector wiring harness. Same problems. Same codes. Can't get code cleared.
