04.5 2500 cluster
Old Oct 10, 2016 | 10:28 PM
qmaqma1's Avatar
Default 04.5 2500 cluster
First problem. 2weeks prior cluster started act weird and gauges stopped working. Now truck will not start. Changed out computer with a running truck and still will not start. Had someone tell me the fuse box could be bad. Swapped it out with a running truck. Swapped out cluster to with a good one. Still noting. Checked power and grounds at computer on engine. Checks good. No power at lift pump on filter housing. Ground shows good. Cluster still not working. Any idea where to start looking. Need wiring diagrams or something. Also no communication at data link connector. There is power there. Won't commicate.
Old Oct 11, 2016 | 12:29 PM
captaindean's Avatar
Here is a website for the 2004 service manual should have wiring diagram
just need to copy and paste it
http://www.mediafire.com/view/8k5u7y...ice_Manual.pdf
