Injen's New Power Flow Air Intake for the 2016 Jeep Grand Cherokee V6 3.0L EcoDiesel
Old Sep 6, 2016 | 11:16 AM
injentechnology's Avatar
FormerVendor
Default Injen's New Power Flow Air Intake for the 2016 Jeep Grand Cherokee V6 3.0L EcoDiesel
Injen is proud to introduce the newest Power Flow cold air intake to our line up. In recent testing, the PF5014 put out 12hp and 16lbs. of torque . Constructed out of 6061-T6 Aluminum, the PF5014 intake provides excellent strength and accentuates the under hood appearance of your vehicle. Injen’s Power Flow line of intake kits are mandrel bent to provide smooth, unrestricted airflow that allows for maximum performance. Handling the filtration duties on this kit is a large SuperNano-Web Dry air filter for great flow and unbeatable filtration. The SuperNano-Web Dry air filter does not require any oil and is easy to clean. Injen Power Flow intakes come complete with all required hardware to allow the customer to have a hassle-free and easy installation.
Performance Air Filter:
This intake system utilizes an 5” inlet dry, SuperNano-Web conical high flow air filter that provides unbeatable protection as well as maximum performance.
One-Piece Heat Shield:
The sturdy 18 Gauge black Powder-Coated Heat Shield Helps to block out engine heat. This heat shield uses factory mounting locations to help provide a fast and simple installation.
MR Technology:
Mega Ram Technology is process used to tune the MAF section of the intake to optimize the horsepower and torque gains well maintaining a safe air fuel ratio.
Mandrel-Bent Tubing:
The 6061-T6 Aluminum Intake Tube is Mandrel-Bent to administer a less restrictive intake air path resulting in smoother airflow and is them powder-coated wrinkel black to add a clean, sleek under hood appearance.
Quality Hardware:
Stainless Steel Band Clamps with inner protective liner and reinforced automotive grade silicone couplers are used to provide the most secure installation available.
Dyno Results:
After hours of design and dyno testing This Power Flow Air Intake system was providing good power racking up 12 additional horsepower and 16 lbs. of torque.
Key Features:
• Patented MR Technology
• Mandrel Bent 6061-T6 Aluminum Induction Tube
• Stainless Steel Band Clamps
• Large Powder-Coated Heat Shield
• 5’’ Inlet SuperNano-Web™ Dry Air Filter
FOR MORE INFORMATION PLEASE VISIT OUR WEBSITE AT INJEN.COM
