Skipping
Old Sep 5, 2016 | 04:23 PM
Brobdingnagian's Avatar
Default Skipping
I had a bad plug on driver side valve cover harness. Replaced the valve cover and replaced external harness connectors. Now there is a slight skip at idle , but it becomes more evident while under a load. Very evident. Could the bad external plug have damaged an injector? Thanks in advance. (3 " down pipe no cat 5" exhaust, just removed TS chip)
Old Sep 7, 2016 | 06:41 AM
joebob3093's Avatar
Moderator
I would do a buzz test to see if they are all firing like they should be
