11 second 12 valve
Old Aug 7, 2016 | 05:44 PM
hunter_01's Avatar
Default 11 second 12 valve
looking at this cummins dont kno much about cummins had duramaxs my whole life i want to get it into the 11s wat would i have swap out to get it there and how much it would cost he said his best time is a 13.62 thanks in advance
Old Aug 8, 2016 | 09:41 AM
wpg6.5's Avatar
first not sure what compound the tows are, i think its the super b and a 66/74 .91 t4. potentially if you pushed them really hard/ hot you may break 11's. first thing id do persoanlly is take the full cut dv's out of there as im sure it smokes like a freight train and probably loses some power there and put some actual streetable dv's in it. jack the timing to about 28 and take it to the track and see how it runs. and learn how to drive the truck. 13.6 seems a bit slow for 500whp so im assuming his driving skilled leave some to be desired. id also get afc (another personal preferance) for ease of tuning on the fly. and not sure what he means by 110 valve springs as they dont exist for 12v. once you start learning how to drive it and start tuning it up you will learn what you need for fuel and air. your likely going to need a bigger compound kit, and possibly slightly larger and possibly better injectors. make sure it has a fuel pressure gauge and look into a tork tek over flow valve for reliable fuel pressure. id start there. also doesnt say tire size or gearing. that can have an affect
Old Aug 8, 2016 | 03:25 PM
hunter_01's Avatar
i was thinking it was slow also my ecsb dmax makes 500 and is faster and first step was gonna be injectors and more pump work thanks for ur input
Old Aug 8, 2016 | 06:52 PM
hunter_01's Avatar
i has also was told to find out wat pump it had he said its a 160 is that good sorry dont kno much about cummins
Old Aug 10, 2016 | 05:22 PM
JBearSVT's Avatar
That truck would be in the 12's if he knew how to drive it... then it would start grenading things. 11's? No. Keep your Dmax.
