Glowshift gauges electrical problem
Old Aug 7, 2016 | 07:58 AM
Running_swift's Avatar
Default Glowshift gauges electrical problem
Got a odd problem with the 02 f250 7.3 I just bought. The already installed glowshift egt and trans temp gauges both work for 5 to 10 seconds after starting the truck then both go to zero. The lights stay on and appear to have full power. If turning the power from off to on position without start, they work fine. I did try a jumper directly off of the battery with no different results. After a long set of trial and error found the issue is the alternator as if the alternator is unplugged then the gauges work fine.
Any advice beyond changing out the alternator? The alternator by prior owner was recently changed with an unbranded alternator. Probably Amazon China special so may give a swap out a try.
Old Aug 14, 2016 | 10:28 PM
Status update. Changed out the alternator and no difference. Did a compare using torque pro and see that once the voltage hits 13.1 the gauges die. Will call glowshift technical support on this. May also try to add a resistor to reduce voltage
But will be a fire risk .
Old Sep 20, 2016 | 06:25 AM
Laugh
Got the solution. Added 3 resistors in parallel at 47r each on The red power wire. This brings the resistor value to 15.6r and allows for 3/4 watt. This makes the gauges work great. I called glowshift a few times and they were no help. Would advise against glowshift.
Old Oct 25, 2016 | 06:15 PM
dsrace's Avatar
ya i had a set of there gauges and customer support is poor. the gauges i had on my current truck and i bet the same on the truck before that were not accurate. not off by a huge amount but enough i won't use them again.
