7.3 powerstroke fuel problem
Old Jul 8, 2016 | 05:19 PM
davidgman's Avatar
Default 7.3 powerstroke fuel problem
hey fellas,
my fuel pump went (the one the frame) i got a replacement for it the pump itself is a shorter cylinder i didn't think anything of it when i got it but i hooked it up and it barley pulled any fuel at all just enough that a little leaked out of the line going up to the front when i took it off , i only bought it cause they guys in the store said that any fuel pump for a diesel v8 will work , i had a choice of another one that was the same size as the original but it was a 24 volt and i thought the pump i needed was a 12 volt. anyways come to find out the ground wire was bad and i probably didnt even need a new pump but i busted a piece of it when i was taking it off anyways preaty twisted any help would appreciated ,cheers
