6.7L Ford Performance Discussion of 6.7 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
2011 f550 Turbo problem
Old Jun 4, 2016 | 08:46 PM
Jake Rodgers's Avatar
Default 2011 f550 Turbo problem
Hey guys. Im working on a buddies f550 and just took it for a test drive and when i stepped on the go pedal it was doggy till around 1500 rpm (only gaining 5psi boost) then it got a kick in the *** and took off and finally started gaining boost. Also it had a hi pitched sound like a jake brake or something was engaged but the truck doesn't have one?! This doesn't seem normal to a Cummins guy. Thanks in advance!
Old Jun 6, 2016 | 04:52 AM
HeavyAssault's Avatar
Sounds like the wastegate may be your issue. Some people just swap in a '15 turbo and fuel pump if the turbo is toast.
