white smoke, no start . Was running fine then it died
Old May 28, 2016 | 12:02 PM
Prentice Evans's Avatar
Default white smoke, no start . Was running fine then it died
Hey guys, I put a new injector pump on my 05 Cummins. Everything ran fine took her out on the road and everything seemed fine. Then later that night was driving about 55 and the truck died. Go to turn it over and no start it acted like it wanted to start a coal came out of the air filter and white smoke out of the exhaust. Water level is still normal no water in the oil what am I looking at here gentlemen. Injectors don't all go out at once do they ?
Old May 28, 2016 | 01:08 PM
Here's a list of codes it's throwing
0483
0073
0462 2503 0243 0463 2509 2127 0628 0646 0341 1223 2122 2769 0882 0973 0251 0107 0073
Old May 29, 2016 | 01:22 AM
11B/11C's Avatar
wow thats a lot. first go through and check all your grounds. the ones on the block and in the engine bay, check the battery terminals too. make sure they are not dirty, cracked or loose. odds are one of those codes is causing multiple codes.
