Cannot Prime Fuel System
Old Apr 14, 2016 | 09:56 PM
GremlinHunter's Avatar
Default Cannot Prime Fuel System
I have great fuel pressure coming from Fass lift pump. Fuel going into injector pump , I have applied direct voltage to faas pump and cracked all injectors and I am not getting air or fuel? Second generation 24 valve 1998.5 dodge
has anyone ever experienced this and can you give me a tip on where to look from here. Stuck on the road... anything helps
Thanks
Old Apr 14, 2016 | 11:37 PM
Just-Another-Dieselguy's Avatar
You need to crank the engine to get a prime. You will get fuel at 1&3 first, and keep cranking and cranking, you will start to get fuel from others. Then close them off and fire it up
