Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
NEW Engine, Wont Start Air Locked?
Old Mar 17, 2016 | 09:56 AM
440wagonr/t's Avatar
Default NEW Engine, Wont Start Air Locked?
Hello guys,
I recently installed a new 6.4 and it will NOT start.
I replaced the longblock, new inector lines and high pressure pump, cleaned injectors and so on.
When i crank it over it builds pressure from 300-900 psi.
I bled air out at the fuel cooler
when i first crank the truck it will build up to 900psi then drop off and stay steady at 3-500psi
It tires to fire, im getting white smoke out of the tail pipe
as a last ditch effort i loosened and bled the two lines that go into the heads. got some more air out
only code is low cranking pressure
then called it quits last night
ANY HELP? keep cranking till she fires?
Old Mar 18, 2016 | 01:46 PM
hello everybody
to answer some questions.
Fuel bowl was filled before craning engine
both the FEED and RETURN have been bled on the fuel cooler
NEW FOMOCO filters in frame and in bowl
All 8 injectors were cleaned, serviced and tested with calibration oil.
Last night i removed the injectors for testing, will update shortly.
thank you
also,
IF YOU HAVE REBUILT A 6.4 and installed it please PM or CALL me, I have a few questions
thank you
Steve
708-699-5902
