2003 f-250 6.0
Old Mar 14, 2016 | 09:53 AM
barrett00j's Avatar
Default 2003 f-250 6.0
Morningjust reaching out to see you have any ideas. I have a 2003 f-250 6.0 ford thathas a P1000 code that will not clear have taken it to one local shop and oneford dealer. The local shop says it’s a ford software problem and the dealersays it because I have a different coolant in it and because I have a coolantfilter on it.and because the truck wont get over 180 deg theys say but I toldthem they where full of crap on that one. Pulled my 36ft over the grapevine andit got about 220 deg All stock expectcoolant filter and exhaust. I changed the oil cooler and egr cooler about 55000’sago truck has 155000 now. Just reaching out for any help I need the p1000cleared to get it smogged. have put many miles on it and it still wont clear.
Thanks
Old Mar 14, 2016 | 03:56 PM
barrett00j's Avatar
Default fords says this is what caused the p1000 code
CK FOR TRUCK WONT PASS SMOG(P1000)IS IN COMPUTER
PERFORMED KOER KOEOTEST FOUNDDTC P0460 FUEL SENDER CIRCUIT FAULT WH
IEL PERFORMING ROAD TEST FOUNDECT TEMP AT 186-188.6 DEGREES NOT
GOING TO NORMAL OPERATING TEMPNEED TO REPLACE THERMOSTATS AND COOLANT
FLUSH. WRONG COOLANT IN VEHICLEHAS RED ORANGE COOLANT SHOULD BE GOLD
COOLANT.RECOMEND THEREMOSTATREPLACEMENT ,COOLANT FLUSH
INCLUDE REPLACEING COOLANTFILTER, AIR FILTER DIRTY.NEED TO COMPLETE DRIVE CYLCE
OR CUSTOMER COULD TAKE AND DRIVETO SET MONITORS
3C3Z*8575*AA THERMOSTAT ASY 1 1 1 62.51
4C3Z*9601*AA ELEMENT ASY - AIR 1 1 1 79.17
D8BZ*13466*A BULB 3 8 8 15.18
VC*7*B ANTI-FREEZE 4 20 20 88.00
COOLANTFILTER 1 0 0 25.00
VC*9* CLEANER - OXIDATIO 1 8 8 26.50
