82 international slammed to stop
Old Mar 11, 2016 | 07:36 PM
Paulbunyan's Avatar
Default 82 international slammed to stop
hello yall, im trying to use the guideline as much as possible. but here is the problem. i was just driving home and came around one of the last corners and the truck slammed to a stop and refuses to go forward. i tried to shift it into nuetral and it goes into reverse and the reverse also works. i used the entire 4 lane intersection on the highway and was able to get it turned around and drove two miles home in reverse.
Year of truck: 1982 International s1824
Motor: dt466 automatic 6sp
Mods:
the only mod is on the fuel pump
How is the truck primarily used:
i use it for towing
When did the issue start, and if it's intermittent or all the time: first time
Anything else that might pertain to the issues at hand: prior to this problem it was difficult getting it into first gear. i believe it is due the clearance on the shift lever.
Any codes, and what are you reading codes with:
no codes too old
Other: the only thing i can think that might cause this is something in transmission, or the torque converter...MAYBE. or maybe the tranny fluid level but those are all stretches. as soon as i post this im going to check the fluid level but please anyone any information would help. if theres any questions ill answer as soon as i can. thank you in advance.
Robert
Old Mar 11, 2016 | 07:41 PM
Paulbunyan's Avatar
I just checked the level and it is above the full line on one side but someone has scribed on the back side "hot" and a line on both sides of it and it is below the lower line on the back.
thank you again
Robert
Old Mar 14, 2016 | 08:49 PM
Paulbunyan's Avatar
CLOSE THIS THREAD please
