Green light on injectors
Old Feb 5, 2016 | 09:37 PM
CumminsCoalRoller24/7's Avatar
Default Green light on injectors
Any one dealt with Randall's performance inc? They have 100hp Bosch injectors +/-1 balance rating tested by exergy for as good a price I've seen- link is here.
Bosch Motorsport 100 hp Injectors randalls-performance
Also would doing the Bosch high pressure feed tubes be worth the extra $300? I replaced 2 leaking ones about 20k ago, my stock injectors are cranky at 216xxx!! I'm excited to get her feeling better but Don't want to make a decision I'll regret! Any info on Randall's or exergy is appreciated!
Old Feb 5, 2016 | 11:56 PM
11B/11C's Avatar
exergy are at the top if not top of the line. i would choose them or 100hp injectors from bms. exgery makes the nozzles and puts them on bms injectors. randalls is an exergy dealer, so i think you would be fine buying from them. here is a list of exergy dealers. Exergy Performance
Old Feb 17, 2016 | 06:34 PM
Ric was great at exnergy but ended up going with DAP and ordering from jkidd on the forum here. Price was cheaper from them and have heard all good things. Install will be this weekend! First rodeo with injectors so a little nervous!
Old Feb 19, 2016 | 10:51 AM
11B/11C's Avatar
i got mine from DAP as well. its a good ideal to change your feed tubes when you change your injectors. injectors are easy to change, just make sure you are clean about it. while you are in there, you might as well do the valve lash as well.
Old Feb 21, 2016 | 06:21 PM
Put em in yesterday- took longer than I thought about 7 hrs, was overly methodical with keeping all in order. Doesn't help having to climb up and down over my bumper! Removing hook from between 5&6 saved lots time after fighting with it for a while. After I started it sounded like &$?! Since exhaust valve had become out of place. Remove hook and double check valve position before buttoning her up and should be good tips for others!
Old Mar 6, 2016 | 09:51 PM
Oatmealman's Avatar
I just put a set of bms +50 in my early 04,love the way they run.I had a bad set of feed tubes that fed my injectors large metal shavings,even though it was my fault ric at exergy took care of me and gave me a big discount on the cleaning and balancing.running a smarty on sw7 trq3 tm2 rp2 and she runs like a raped ape and just barely hazes on a stock charger.
