6.7 Liter Dodge Cummins 2013+ Discussion of 6.7 Liter Dodge Cummins Diesels with DOC&DPF
THE INJEN EVO8003 AIR INTAKE FOR THE 2013-15 DODGE 2500 / 3500 CUMMINS DIESEL 6.7L
Old Feb 4, 2016 | 04:15 PM
injentechnology's Avatar
FormerVendor
Default THE INJEN EVO8003 AIR INTAKE FOR THE 2013-15 DODGE 2500 / 3500 CUMMINS DIESEL 6.7L
The 2013 -15 RAM pickup 2500 and 3500 models carry the B series 6.7L engine - the latest version of the powerful Chevy diesel B Series. It is the largest straight-six engine produced for a light duty truck. The 6.7L B series produces 385 horsepower at 2800 RPM and 865 pound-feet at 1600 RPM in the 2007.5 and newer Dodge 2500/3500 pickup trucks ( with the Chrysler-built six-speed 68RFE automatic transmission). It is slightly less powerful in the manual transmission.
Edmunds, the automotive resource since the 1960’s, had this to say about the Dodge 2500 and 3500 6.7L vehicles:
Pros
Monumental torque with diesel and automatic powertrain; high-quality cabin; Mega Cab's roomy rear seat; highly off-road-capable Power Wagon version; quiet, comfortable ride.
Cons
Diesel's lower output with the manual transmission.
In Edmunds’ testing, a 4WD Ram 2500 crew cab equipped with the 6.7-liter turbodiesel accelerated from zero to 60 mph in 8.7 seconds…
But of course, they didn’t have the Injen Evolution EVO8003 installed.
If they had, they would have increased their horsepower and torque significantly. The Evolution Air Induction series is a thoughtfully designed line of intakes that are the next step in a long line of Injen Technology’s automotive innovations.
Like all of our products in the Evolution line, the EVO8003 is designed using the latest CMM Laser Scanning hardware and SolidWorks 3D CAD software. All prototypes are printed on one of our state of the art 3D printers, and then they are extensively tested on our in house Dyno.
Evolution Intakes are Injen Technology’s newest state of the art induction kits made of rotomolded cross linked high density polyethylene for superior quality and durability.
Our rotomolded intake boxes are designed to incorporate the largest dry filter on the market.
The SuperNano Web Fiber filter utilizes a micro fiber web on the surface, in order to capture airborne contaminants. The new EVO air intakes come with stainless steel hardware and automotive grade urethane couplers as well as the first built-in filter minder for quick, easy and accurate filter inspection.
The style and look of these massive induction kits is very impressive and their functionality is second to none. Everything is completely done in house - in Pomona California. Injen is dedicated to the principle of Made in the USA!
Straight Forward Installation. The Injen Evolution Cold Air Intake Kit is designed to install easily with just basic hand tools. No extra modifications or special tools are required for proper installation. All necessary parts and instructions are included.
No Tune Required. You read that correctly. Unlike other Cold Air Intakes on the market, the Injen Evolution CAI does not require a computer re-tune. The engineers at Injen have designed, tuned, and dyno-tested this cold air intake to improve your Ram’s power using the stock factory tune.
As you can see in the Dyno Test -- The EVO8003 provides the 2013-15 Dodge Ram 2500 / 3550 with real gains in HP and in TQ.
Features and benefits of Injen’s EVOLUTION Air Induction Systems:
- Dyno tuned as a System for GUARANTEED safe horsepower and torque gains
- Officially the largest SuperNano-Web dry filter on the market.
- The first stand-alone air filter chamber for ample on-demand air supply.
- Sleek and sexy design lines for unmatched looks under your hood.
- The first built-in filter minder for quick, easy and accurate filter inspection
- Designed and built in the USA from cross-linked polyethylene for outstanding durability and heat insulation
- Durable stainless steel hardware and automotive grade hose couplers included
- The perfect OE fitment; just drop into the original mounting points, fasten clamps, and drive away!
- All Injen intake systems are designed and manufactured with pride in the USA
