New to the Common Rail
Old Feb 3, 2016 | 08:02 PM
MechanicalDiesel's Avatar
Default New to the Common Rail
Hey guys, I just recently bought a 2006 ram 2500 its got efi live a 5" exhaust, triple disk converter, semi built tranny with a billet input shaft. Is there anything I should look out for with this year truck? Any common problems I can fix before they happen?
Old Feb 3, 2016 | 08:35 PM
CumminsCoalRoller24/7's Avatar
I have the same year- front end components as usual(tie rods and ball joints)- depending on mileage injectors and crank case gasket/oil pan gasket! Other than that nothing as long as you keep changing oil/fuel filters!
Old Feb 3, 2016 | 10:05 PM
11B/11C's Avatar
check the 4th fuel line every now and then to make the bracket is tight. they tend to get loose and end up cracking or wearing a hole in the fuel line, then fuel sprays every where.
Old Feb 7, 2016 | 03:21 PM
AHolt's Avatar
What kind of fuel filtration is on truck ?
You need a water separator and 2 micron filter.
Old Feb 7, 2016 | 09:52 PM
11B/11C's Avatar
there is no true 2 micron filter. the cat 2 micron filter is just here say and no data to show that it is.
