Oil and water mixing problems
Old Jan 31, 2016 | 05:41 PM
Bacon_11's Avatar
Default Oil and water mixing problems
I have an 02 7.3 powerstroke my coolant was full of oil when I checked but no coolant in my oil... so did some research and determined it was my oil cooler so I replaced it today... now I still have oil mixing with my coolant and now have coolant in my oil....
Old Jan 31, 2016 | 11:20 PM
97cummins's Avatar
As for the oil still in the coolant, your system may still be trying to clean out the oil out of your coolant after the oil cooler change.
As for the coolant in the oil,possibly head gasket.
Old Feb 1, 2016 | 06:20 PM
Bacon_11's Avatar
Thanks man but I think I found the problem whenever I put the oil cooler on I had pinched a ring on it allowing both to mix
Old Feb 2, 2016 | 01:26 PM
Kooper's Avatar
Had the same problem with mine^^^
Fixed that then had fuel in my coolant turned out to be injector cups Fixed now though!
