Cold start/No start problem
Old Jan 27, 2016 | 07:58 AM
Sphinxj13's Avatar
Default Cold start/No start problem
Hi everyone,
I'm having issues with truck not starting when it's cold. Truck has 194k on it so figured it was due to worn injectors so replaced all of them and truck will start right up after then next morning truck will not start...before I replaced the injectors the truck would only truck after it has been plugged in for few hours. Looking for any ideas or help!
Thank you
Old Jan 27, 2016 | 09:32 AM
cerberus60's Avatar
What injectors and cross over tubes did you use? Did you follow the install sequence correctly? If it starts warm but not cold you still have an issue with fuel pressure not raising fast enough, the question is where now.
Old Jan 27, 2016 | 09:35 AM
Sphinxj13's Avatar
I do not know the name of the injectors off the top of my head at the moment but I reused the crossover tubes and followed sequence exactly and I changed them last night outside when temp was 27 degrees and the injectors had been sitting out there all day and it started right away once I finished putting it all back together.
Old Jan 27, 2016 | 09:38 AM
Sphinxj13's Avatar
I also tried unplugging the FCA and still wouldn't start
