When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
So I figured I should put a build thread somewhere.. Trucks a 93 with an upgraded factory turbo.
Goal is around 300hp, and yes i know that's a lot for these motors.
So far I have the upgraded turbo and a 3" downpipe, not the stock unit. Boost gauge went in today.
Getting a pyro, oil pressure, and water temp (eventually!). Getting a cold air intake made from 3 inch aluminum tubing, as well as plumbing for the all aluminum air-to-air 7.3l psd inter cooler. ARP head studs and most likely new gaskets are in the works. I have a previous post called "bored out 7.3l turbo" I mistakenly thought it was bored out but it was just bored and 2 cylinders resleeved, all the receipts I got to do with the motor are in that post I'll post em here too eventually. 3" downpipe to 3" exhaust most likely running a single 6" miter cut stack. Once the head studs and gauges are in I'm going to be playing with my waste gate and injector pump and see what numbers I can get out of it. I will keep posting updates and pictures as I go. Please feel free to ask questions or give suggestions, (especially suggestions)
