good or bad injectors to use
Old Jan 21, 2016 | 08:21 AM
Don Baker's Avatar
Default good or bad injectors to use
rebuilding my industrial 5.9 cummins and looking for more performance and mpg out of it;;can anyone tell me if these injectors be anygood to get;;Pensacola fuel injection brand;;stage1 part code 1000 rated at 40hp;;;I have the ve pump.
Old Feb 15, 2016 | 09:39 AM
jkidd's Avatar
Do you have 7mm or 9mm wide injector tips? What is the spray angle of the injectors? What turbo and what is your HP goal. The injectors you are asking about may be the wrong spray pattern and give you no more HP than what you already have. If you have a cummins injector replacement part # from your ESN I can help you.
We have injectors in 5, 6 and 7 hole. Stock all the way up to 5x.025. Gotta know more info before making a recommendation.
