Specific Purpose General Discussion General Diesel Discussion of all Vehicles with Diesel Engines Used for a Specific Purpose , Farming , Transporting , Boating , Construction
will dodge head fit my industrail engine
Old Jan 16, 2016 | 03:27 AM
Don Baker's Avatar
Default will dodge head fit my industrail engine
will a 1st generation dodge cummins 5.9 12 valve head fit and work on my 5.9 12 valve industrial cummins engine?my eng serial #44150875;;;;i'm also buying ne injectors if that makes any difference;;was told the industrial has 9mm and the dodge uses 7mm but he didn't know if the dodge injectors will work on my eng..?
Old Apr 21, 2016 | 07:39 AM
gh0stman's Avatar
Depending on pump differences between industrial and dodge, you might have to get the new injectors pop psi set to the industrial engine specs. The head should work.
