Cranking issue
Old Jan 4, 2016 | 02:39 PM
hammerdown91's Avatar
Default Cranking issue
I recently did a gasket rebuild on my ve pump. I hooked everything back up, bled the lines, checked for leaks, and it still will not fire up. I've tried soaking a rag in gas and holding it to the air horn, it gives it a little more pep, but still not running. I'm about 100% sure my lines are on correct. But I'm puzzled. Anyone have any ideas?
Old Feb 24, 2016 | 11:45 PM
Rga1991's Avatar
I shared this a little bit ago for someone else but did you mark the throttle lever with the throttle shaft I re sealed mine and it would only idle at full throttle adjusted the lever a few times then got it right hope it helps
