truck died and wont start
Old Dec 31, 2015 | 04:54 PM
MITCH 1979's Avatar
Default truck died and wont start
rRECENTLY CHANGED OIL FILTERS (AIR OIL FUEL RAN IT ABOUT 1000 MILES . ALSO CHANGED A WEAK BATTERY AND DOING SO THE SELONOID FOR THE AIR HEATER DISCONECTED REPLACED IT WITH A RANDOM SELINOID TRUCK STARTED AND RAN PERFECTLY FOR A WHOLE DAY. NEXT DAY STARTED IT UP IDLED FOR 20 MINS PUT IT IN DRIVE AND TRUCK JUST DIED. LIKE I FLICKED A SWITCH. TRUCK WAS CRANKING BUT WASNT ABLE TO START. ITS NOW AT THE DEALER AND THE COMPUTER READS FUEL PRESSURE @ 49 PSI WHEN HIGH PRESSURE SENSOR IS CONNECTED AND 27000 PSI WHEN DISCONECTED ... IS IT THE PUMP SENSOR OR INJECTORS?
Old Jan 8, 2016 | 11:27 AM
Jet A Fuel's Avatar
Have you determined what is causing the problem? could be a faulty FCA or a bad connection at the CP3. It maybe related to the recent maintenance.
Old Jan 9, 2016 | 12:55 PM
jkidd's Avatar
If you are still having issues call in Monday and talk to Mitchell 801-618-2151 He can help you troubleshoot or with parts.
