holset super hx40
Old Dec 15, 2015 | 03:41 PM
redneck_cummins's Avatar
Default holset super hx40
So I know a guy that's wanting to run one of these turbos on his truck but he's unsure if the 16cm exhaust housing would be too laggy to tow an daily drive with it. He's wanting to run 100horse injectors an edge juice an a Hamilton towing cam. Would this turbo be good for his needs he only tows an daily drives with the truck.
Old Dec 17, 2015 | 01:12 PM
jkidd's Avatar
If the turbo is a good price go for it. Go with 125HP injectors. Its a little laggier than a 62/65 but its a solid turbo and has the better 60mm compressor wheel and the 16cm housing. Keep in mind you can get a super B turbo (that will spool faster and will almost support as much HP) for about $1000.
Quadzilla adrenaline is back. Cam is not really necessary.
Old Dec 22, 2015 | 08:21 PM
Ok thanks Jkidd. Would a 63/68 turbo be suitable for towing an dd with the setup I mentioned in the first post an what size exhaust housing would you recommend?
Old Dec 23, 2015 | 10:50 AM
NadirPoint's Avatar
I've been running that turbo on my 1st Gen with 5x12's for a few years now and it works great - no spool or lag issue whatsoever.
Old Dec 23, 2015 | 01:37 PM
jkidd's Avatar
you can tow with a 63/68 or better is the 62FMW. I will send you a link to some of our combo deals.
Old Dec 23, 2015 | 01:40 PM
OK an what would you recommend for a good towing build ie- injector size chip/programmer?
Old Dec 24, 2015 | 11:35 AM
jkidd's Avatar
Adrenaline + FMW62 + 7x.010sac and some head studs. 550HP and tows well.
Old Dec 24, 2015 | 03:24 PM
The 7x.010 is 175hp correct?
Old Apr 24, 2016 | 05:41 AM
Chris Baker's Avatar
Default Curiosity
How does that super B turbo compare with the stock HX35 (I think) on my 01? Would it spool faster? Would it install without mods to other components?
Old Apr 25, 2016 | 11:11 AM
gh0stman's Avatar
Super B is a better turbo than the HX35. It wont spool as fast but it will support more air and higher boost pressures.
