Injector issue
Old Dec 9, 2015 | 05:29 PM
mudduck3975's Avatar
Default Injector issue
I have a 2006 Cummins. Im trying to determine if I have a bad injector pump of just some clogged injectors.
Have an Air dog FP 100 and it is working fine
Old Dec 9, 2015 | 06:31 PM
Jet A Fuel's Avatar
What is happening to make you think your injector/ CP3 are bad?
Old Dec 9, 2015 | 09:05 PM
11B/11C's Avatar
as stated already, we need to know whats going on with the truck for us to help.
Old Dec 10, 2015 | 07:25 AM
First thing is had large amounts of black smoke while running. Also the air dog pump had gone about and I drove the truck for a few months with just CP3 pump.
The truck wouldn't crank as of yesterday morning. I took the fuel line off the rail to see if fuel would come out while turning truck over. A small amount came out. ( not sure how much was supposed to come out).
I have injector issues in the past and it acted this same way just wanting to make sure the Cp3 pump isn't going bad as well
Old Dec 10, 2015 | 07:21 PM
Jet A Fuel's Avatar
I am sure it wasn't doing the pump any good with no lift pump pressure. But the Cp3 pump is pretty stout the lift pump pressure for it is only about 6 PSI.
You should have a high pressure at the fuel rail be extremely careful. Fuel should spray everywhere and make a giant mess if the pump is making pressure.
Do you have any other details about the truck?
Any programmer or other mods?
Old Dec 11, 2015 | 09:09 AM
jkidd's Avatar
Get fuel pressure to the CP3. If you don't have fuel pressure you may have a no start issue and poor running/ bad atomization/ lots of smoke from low rail pressure.
Old Dec 11, 2015 | 04:30 PM
I took all the fuel lines off the fuel rail to start pyllunv the injectors to clean. While all apart I turned the engine over and no fuel out of fuel rail. I will clean the injectors and put all back together. From what I can gather from the information everyone is telling me sounds like CP3 pump is bad. Thank you for all the advise. I will update once I clean injectors and try to start truck again.
Old Dec 15, 2015 | 08:03 PM
cerberus60's Avatar
I hope you did not take the injectors apart for cleaning.
Old Dec 15, 2015 | 10:02 PM
Why do u say that?
Old Dec 15, 2015 | 10:03 PM
I have figured out it is the CP3 pump. Ordered it and hope to have it on in a few days.
