1998 Ranger conversion
Old Nov 30, 2015 | 10:56 PM
thehighwayman's Avatar
Default 1998 Ranger conversion
Hi, I am new to diesel conversions, i have read a little bit about them, and i am interested in doing one. I have a 1998 Ford Ranger 2.5 liter 4 cylinder. I was wondering if you guys have any tips, engine suggestions, that kind of stuff. I don't care that much about speed, as long as I get over 55mph I'm okay with it. I'm looking for an engine with a lot of torque and decent fuel eco. Thanks guys.
Old Dec 1, 2015 | 04:46 AM
gh0stman's Avatar
Have you checked out the 4BT Cummins engines? They will give you decent power and will not damage the frame. I know there are other good choices out there too but not familiar with the others. I would stick to a 4 cylinder diesel, because anything bigger will weight about as much as that truck does.
Old Dec 1, 2015 | 07:14 AM
yellow68gto's Avatar
The truck you are starting with is a great platform. The 4bt is a good engine but very heavy and you would need to switch to a big ttruck transmission.
Other options would be the kubota , tdi vw and I believe the Perkins from the older rangers.
I have no experience with the last two. There are many guys that have swapped the kubotas into vehicles and are very happy with them and I believe most are seeing high 30s mpg.
I will let them chime in
Thanks
Ken
SPMACHINING
Old Dec 1, 2015 | 09:34 AM
Thanks, I'll look into it.
Old Dec 1, 2015 | 11:48 AM
I looked at the Cummins engine, it seemed like a good choice, has anybody ever used the kubota v3800?
Old Dec 1, 2015 | 11:58 AM
If I could find a v3800 I would ****** one up in a heart beat. The easiest Kubota to find is the v2203 and generally can be had for 1200 or so.
Once turboed they will make plenty of power to propel a truck of your size nicely
Old Dec 1, 2015 | 12:12 PM
Thanks, do you know what turbo is the best to use on the v2203? And engines aren't really a problem for me, me dad owns an equipment rental company and has plenty of spare engines, I am really looking for at least 200lb/ft at peak basically
Old Dec 1, 2015 | 12:25 PM
gh0stman's Avatar
Its not hard to avg (from what I have seen) 300ish ftlbs. out of a 4cylinder diesel.
Old Dec 1, 2015 | 12:55 PM
Do you know what engine? Or is that the average? I can't find that many specs on the kubota engines.
Old Dec 1, 2015 | 01:03 PM
gh0stman's Avatar
Here is some specs from a couple engines.
Kubota Engine America - V3800-CR-TI-E4B
4BT (3.9L) Cummins Specs & Information
http://www.konekesko.com/Global/Kubo...2203-M-E3B.pdf
