2000 7.3 crank no start
Im trying to fix my dads friends truck. 2000 7.3. Cranks but will not start, no smoke not even trying to start. Got a snap on reader and found when doing buzz test that one will buzz for a split second then scanner will abort test. New icp, new cps, tried a tester idm that i know was good 1 year ago and still no start, im kind of wondering if my tester idm went bad, but i doubt it. Tach moves while cranking, fuel pump is running, there is diesel in the tank, checked all fuses and relays. There is 1800 psi icp. Ipr was at 14-15 key on, 40-50 cranking. My dads friend said he pulled ipr and cleaned and that it was stuck and he broke it free, cleaned and re installed. No check engine lights. Need some help!!!!
