Need more power
Old Nov 18, 2015 | 08:02 PM
Ltm2425's Avatar
Default Need more power
Got a 1991 Cummins intercooled with a 5 speed has 3200 gov springs pump turned way up 140 HP injectors schwitzer turbo (don't know the size) air intake four inch turbo back into five inch stack. Want more power without spending 1000s I have boost and pyro gauges so good there and getting a dual disk clutch so good there. Thanks in advance for any help!
Old Nov 19, 2015 | 02:33 AM
u2slow's Avatar
what axle gears? taller ratio (numerically lower) might actually help.
Old Nov 19, 2015 | 08:51 PM
Ltm2425's Avatar
Its the 3.55 or what ever. Thought about that but I also pull trailers. (20,000 lb) believe it or not so I'd like to not lug it too much more.
Old Nov 24, 2015 | 01:32 PM
u2slow's Avatar
I retract the ratio change suggestion for 20k# towing
What's your fuel pressure like?
Old Nov 24, 2015 | 09:51 PM
Ltm2425's Avatar
I don't exactly but pumps turned up and when its running 30 pounds of boost it will still haze black so its got fuel.
