2010 Duramax Camaro SS
Old Nov 18, 2015 | 05:53 PM
OneofWon's Avatar
Default 2010 Duramax Camaro SS
Hello, my name is Nate and just thought I'd give this forum stuff a try as I dont have much free time.
I am in the process of building a 2010 SS Camaro with a 2010 LMM Duramax engine, at this point the Engine and trans is mounted into the car and I am beginning down the long road of wiring to make it a fully functioning driver.
You may have seen my last build, the Cummins Charger with a 5.9/NV4500 that I have been daily driving for the last year and have about 15,000 miles on it now.
Feel free to subscribe to my youtube channel as I occasioanlly post videos of the diesel cars and will work on posting more about the Camaro. the amount of interest I attract will motivate me to post more pics, videos and information as things progress.
Excited to meet some new friends on here, and willing to help with what I can. I am a jack of all trades, but a master of none..
Here is a few pics, I will do a small write up on my adventure so far if there is an audience for it.
https://www.flickr.com/photos/136055.../shares/HE1gsZ
Youtube - https://www.youtube.com/channel/UCPt...3nen6lYu6qxHw/
(Tried attached photos, didnt work, so I linked them)
Old Nov 20, 2015 | 10:00 AM
FTE's Avatar
FTE
Nice! Looking forward to many updates!
Old Nov 23, 2015 | 12:44 PM
gh0stman's Avatar
Seems like you have an interesting project on your hands. Whats next after this one? powerstroke into a mustang?
Old Nov 24, 2015 | 12:50 AM
OneofWon's Avatar
Thanks! We shall see...
Old Nov 24, 2015 | 01:03 AM
OneofWon's Avatar
So I ended up getting a 2010 LMM with 8000 miles on it and a 2010 6L90e transmission with all the wiring. I am very happ with the spotless engine and how nicely the transmission fit.
I ended up lowing the sub frame 3 inches from the body to make room for the stock hood, and will be lifting the struts 2" to bring the ground clearance back up. which will level the car out as well. I should have engine and transmission mounted by the end of the week as well as the custom drive shaft and gweebo adapter.
The next step is getting the intercooler, radiator, and fuel system mounted and plumbed.
I am getting closer to the wiring portion of things and am seeking someone that is very well versed with these systems to make the engine and transmission talk to the car, like I said I have all the wiring from a donor vehicle that the engine and trans came from. If the price is fair I would be willing to bring the whole car to a select individual. Just figured I would see if anyone was interested in taking this on before I start diving into it myself. I want everything to function including powering the ecm, fuel pump, tps, guages, OBD port for Edge CTS and general diagnostics. Everything on the car side already functions as it should(windows, hvac, radio, lights etc).
So if you know someone that is HIGHLY skilled, let them know and send me a PM if they are interested.
Old Nov 24, 2015 | 04:10 AM
gh0stman's Avatar
Give Painless Wiring a call. They specialize in "custom" wiring harnesses. Im not familiar with the 6l90e. But I assume it is electronically controlled. Did it come behind the duramax? If so you could probably use the donor computers to make them talk. But getting the foreign objects to communicate with the Camaro is past my expertise.
Old Nov 25, 2015 | 08:15 AM
OneofWon's Avatar
I actually spoke with some Painless Wiring guys at SEMA, wasnt too impressed with them and their quality.. butt connectors and low quality connectors.. ish. You would think they would atleast step up their quality in their expo samples haha.
Old Dec 4, 2015 | 06:54 PM
Golddigger's Avatar
Cool build!
Old Jan 2, 2016 | 02:03 PM
OneofWon's Avatar
So I have been busy with multiple things and tending to forum updates is a tall order but here is some info and pics for you.
Steering: I managed to keep the steering rack in its stock location(which was a big hurdle as previously explained, the only modification done to steering was lengthening the shaft from the column 2" since the sub frame was lowered, it fits snugly passed the oil cooler with barely any clearance. Yes, I managed to make this happen with the stock oil cooler/filter setup which I couldn't believe and was making preparations to delete. it has about .5" of clearance from the body(the oil filter).
Exhaust Manifolds: I ended up using exhaust manifolds from a GMC Kodiak as the up pipe flange is located behind the head rather than next to it which made valuable clearance for the engine to fit where it needs to be. I got rid of the heat shields and had them Ceramic coated for a better look as well as better performance. Also the Kodiak exhaust manifolds/up pipes/down pipe are much less restrictive and do not have the flattened tubes like you may be used to.
Intake Bridge: I had to chop off the 2 bolt flange and fabricate a 2.5" hose coupler so I could run a 90 degree silicone hose right out of its place as there is no room for a fancy egr delete pipe under this hood.
Thermostat Housing: The thermostat housing was modified to allow for the coolant hose to be routed easier
Radiator: I purchased a Mishimoto performance direct replacement aluminum radiator for the Camaro which is 2.5 times thicker than stock. I removed and capped the stock inlet and outlet and capped them off and installed larger inlet and outlets to accommodate more flow for the engine, also the placement was changed on both to accommodate the engine.
Intercooler: I am not sure what brand it is but I hit the jackpot on ebay when I through a $60 bid on this one thinking it was some cheap garbage(was intending on using it for mock up). it has to way over 50 lbs and is built extremely well with very thick aluminum cores and tanks. it fits the location perfectly with the tubes clearing around each end of the radiator.
I also had to cut the mount for radiator and move it back up to stock height since the sub frame was dropped 3 inches.
Drive Shaft: I obviously had to build a custom drive shaft for it which was pretty straightforward except for the adapter I made to get rid of the GWEBO joint(rubber flange type joints that all newer cars run). You can see the adapter in the pictures, it pretty much adapts the 3 bolt gwebo pattern to a 4 bolt drive shaft flange, I had to do the same thing on the Charger.
At this point the engine and transmission are mounted, the radiator and inter cooler are mounted most the piping is complete, drive shaft is installed the main fabrication is complete.
What I am waiting on is the wiring harness which I sent down to a great guy named Ken in Florida, he does standalone Duramax harnesses on the side and I believe he works for GE as an electrical engineer. He is very fair priced and his communication is excellent. He is very intelligent and can explain things to someone with little knowledge on the subject. You wont find anyone cheaper and he may give you a discount if you mention my build as he was excited to be a part of it. Note: I searched near and far for this service and have high standards.
Also, he has a few low cost connections on getting the ecm reprogrammed to work with the harness and further more to function without the EGR system.
Here is his Website - Duramax
So once the wiring is back in my hands and installed along with the ecm hopefully it will go smoothly and we will see how a 6.6 duramax powered Camaro performs! Then I can start ironing out all the kinks such as gauges(I will run an edge CTS2 for the time being), fuel tank, exhaust system, cleaning up the odds and ends, etc...
As for the gauges functioning, Ken said that they may all function perfectly or they may not function at all once the can bus wires are connected between the engine computer and the body computer. I'm hoping things go smoothly as far as the gauges but am prepared for the challenge if they do not function.
Photos:
https://www.flickr.com/photos/136055.../shares/pKe5yu
Old Jan 2, 2016 | 07:36 PM
Waxball88's Avatar
sounds a little bonkers to me
