Tires seem to slip or stutter on right hand turns
Old Oct 29, 2015 | 04:24 PM
oznation's Avatar
Default Tires seem to slip or stutter on right hand turns
It's an 03 2wd and when I turn right the tires seems to slip like its losing traction. It does not do it when I turn left. Wet ground it's worse but will also do it on dry pavement. Any ideas?
Old Nov 1, 2015 | 08:16 AM
dangerous1965's Avatar
If your on the gas it will lock the diff!
Old Nov 1, 2015 | 08:21 AM
chopforeman's Avatar
You need to add this stuff to you diff.
Motorcraft Additive Friction Modifier
ever time i do a oil change in my diff i add a bottle of this.
your limited slip clutch in your diff is sticky
