Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
Electrical Question - Will this work?
Old May 21, 2008 | 09:50 PM
Wyatt Earp's Avatar
Default Electrical Question - Will this work?
I'm wondering if anyone can tell me if I'm on to something with the following idea:
Relay 1 (the transmission switch) would be a SPDT
86 - from transmission
30 - from battery
87a - N/C
87 - N/O power to lights
85 - ground
Relay 2 would be for the cab switch and is a SPST
86 - from switch
30 - from N/C (87a) of relay 1
85 - ground
My idea goes like this - generally the cab switch is off (N/O) and the lights are only generally triggered by the transmission switch. If the 86 on relay 1 is NOT energized the power from 30 (#1) goes through 87a (#1) and heads to 30 (#2) and stops and is available for user input from cab switch. If 86 (#1) is energized (Closed) then the power 30 (#1) runs through 87 (#1) and powers the lamps. If the cab switch (relay 2) is used when the truck is in reverse it wouldn't matter because it is already energized but should the transmission go back to neutral (open switch) then the power would be as explained above and now go from 30 (#2) and travel through 87 (#2) and power the lamps.
So, is that the right idea? Please let me know if I'm on to something as this is all a bit too confusing for me.
Old May 21, 2008 | 11:37 PM
2500HeavyDuty's Avatar
what lights r you talkin about?
Old May 22, 2008 | 12:22 AM
Wyatt Earp's Avatar
sorry, oem rev lamps as well as aux tail lamps. want them to either all 4 come on with switch or with stick shift.
Old May 22, 2008 | 08:03 AM
jdugie123's Avatar
you are on the right track i will try and draw up a diagram today some time and make sure it will work but it all sounds good about the way i have mine done
Old May 22, 2008 | 09:11 AM
Wyatt Earp's Avatar
I have a sketch just no way currently of getting up on line.
Old May 22, 2008 | 09:18 AM
AndyMan's Avatar
I've got a bosch relay guide that I picked up from somewhere. It's too big to attach to the message, but I might be able to e-mail it to you. It's 3.5MB. It's a real good guide, lots of nifty ideas as well.
Old May 22, 2008 | 09:59 AM
Wyatt Earp's Avatar
Andy,
send it to me devon.wyatt@telus.net
Thanks.
Old May 22, 2008 | 12:07 PM
AndyMan's Avatar
Done sir. If you don't get it let me know.
Thanks,
Andy
Old May 22, 2008 | 12:54 PM
Wyatt Earp's Avatar
Got it. I looked at it and can't find an example of what I'm trying to do. I will need to look closer I think.
thanks again.
Old May 22, 2008 | 12:59 PM
AndyMan's Avatar
Yeah, there may or may not be an example of exactly what you're after, but there are some really good examples and informaiton in there.
