04 Cummins 2wd squeaking only when I turn right ????
Old Oct 15, 2015 | 02:22 PM
KiltEmWhooptem's Avatar
Default 04 Cummins 2wd squeaking only when I turn right ????
Just like the title says its squeaking only when I turn right it didn't start doing it but a week ago and started getting worse I've seen some thing about it on here but that was for 4wd so just want to make sure I get the right stuff. Thanks
Old Oct 15, 2015 | 04:48 PM
chopforeman's Avatar
it your wheel bearing. jack it up and check the wheel bearing it will only squeak when you put pressure on it. I had to change both of mind on my 2wd diesel at 100,000 km(62500 miles)
Old Oct 16, 2015 | 02:55 PM
Yea I did that's it's definitely the bearing I a do both how much will that cost me and is there any performance bearing I can buy someone said they make some that will get better mpg idk tho
Old Oct 16, 2015 | 10:06 PM
I did my front two wheel bearings myself . The bearings were 200.00 each.There is no performance bearings.
