getting bad gas mileage.
Old Oct 13, 2015 | 06:40 AM
doc89holliday's Avatar
Question getting bad gas mileage.
Hey,
I am getting 12-16 mpg in my 03 Cummins, just over 200k. I have changed the air and fuel filters, put fuel rail cleaner through it, cleaned off the ait and map sensors still got about 3k miles before i need to change the oil and im not getting any fault codes on the obd2. I dont know what to do at this point i do have access to my own obd2 so i need to take readings just let me know. Any help would be appreciated.
Doc89holliay
Old Oct 13, 2015 | 08:40 AM
Jet A Fuel's Avatar
Please let us know if you have any mods or if the truck is stock.
thanks
Old Oct 13, 2015 | 11:54 AM
gunman41mag's Avatar
Moderator
Have you lifted or added bigger tires
Old Oct 13, 2015 | 05:07 PM
hutch311's Avatar
Also could be where hes getting his fuel from too.
Old Oct 13, 2015 | 05:24 PM
The truck is bone stock. 2500, 265/70r17 tires. I have changed nothing in the past 6 months but oil and the above items. Thats when i bought the truck
Old Oct 13, 2015 | 07:58 PM
dangerous1965's Avatar
Any light smoke on start up?
Old Oct 14, 2015 | 05:31 AM
none
Old Oct 14, 2015 | 04:02 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
just wondering if run have run the valves lately. boost leaks will hurt too. to many things like injectors etc to list
Old Oct 15, 2015 | 04:13 AM
Question
I dont understand what you mean. Run the valves like just running the engine or what. Are you talking about tracing a fuel leak in the last part or what.
Old Oct 15, 2015 | 07:05 AM
diesel pap's Avatar
by running the valves i mean check valve lash. the boost leaks i talked about can be intercooler or tubes leaking. injectors can get worn and cause problems too
