Light Engine miss in lower to mid rpm
Old Sep 3, 2015 | 06:57 AM
Zach56238's Avatar
Default Light Engine miss in lower to mid rpm
So the new 02 f350 7.3 with 204k miles I bought has a slight miss to it. I can feel it sometimes at idle and sometimes not but always feel it from around 1000rpm until turbo spools up enough to mostly level it out. Running 70-75 down the hwy you can just slightly feel the un balance of it if the road is smooth enough. Since I have absolutely no blow by, I'm assuming possibly injector?
My icp is leaking oil internally and I will replace it today after work but while running if I unplug it it idles differently and check engine light comes on so I'm assuming that is not the issue?
I was told the truck just had injectors installed within the last 6 months but I have not pulled valve covers to check for myself or check to see if harnesses were replaced either.
Any ideas would be greatly epreciate. Thanks
burndiesel
10
Feb 7, 2023 01:15 AM
gauge1325
May 3, 2015 01:33 PM
dieseltuff
Ford Powerstroke 08-10 6.4L
Apr 27, 2015 07:18 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
05 Cummins 86ed
Feb 9, 2015 01:54 AM
