94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
97 f350 7.3 PS. Power problems
Old Aug 19, 2015 | 09:28 AM
Treeman69's Avatar
Default 97 f350 7.3 PS. Power problems
My truck has 320,000 on it, it's a work truck that has been pulling, pushing and hauling from day 1. Lack of power over the last year has increasingly worsened. When going up hills with the pedal to the floor it sounds like it spits and pops and won't go over 40mph. Even empty, seems to idle ok but a little rough.......any ideas?
Old Aug 19, 2015 | 09:55 AM
joebob3093's Avatar
Moderator
Filters and all that good?
Old Aug 19, 2015 | 10:07 AM
Treeman69's Avatar
Was thinking it had not been that long since I replaced the fuel filter, picki,g one up now to do it again though. Any other filters that I should change?
Thanks for your help I really need to fix this!
Old Aug 19, 2015 | 01:46 PM
Treeman69's Avatar
Last time I changed the fuel filter there was a bit of sediment at the bottom so I drained in and cleaned it out the best I could, I have plenty of fuel pressure when it's running 55+ , should I clean the sediment again and is there anything else to clean when changing fuel filter?
Old Aug 19, 2015 | 06:38 PM
joebob3093's Avatar
Moderator
Drain it, pop a new filter in and see if that helps. Don't really need to clean anything
Old Aug 20, 2015 | 08:27 AM
Treeman69's Avatar
Replaced the fuel filter, really no change in the power problem, still struggling up hills empty and rough running, something just isn't right....next idea please?
Old Aug 20, 2015 | 09:33 AM
joebob3093's Avatar
Moderator
Scan it, do a buzz and contribution test on it as well
Old Aug 20, 2015 | 09:36 AM
Treeman69's Avatar
Can you explain, what is needed and how to?
I'm not a mechanic but can pretty much fix anything with a little guidance?
Thanks
Old Aug 20, 2015 | 06:43 PM
joebob3093's Avatar
Moderator
You need a scan tool to scan it and do these tests. The buzz tests the injector solenoids and the contribution test makes sure all the injectors are contributing the same.
Msc
Apr 23, 2015 06:21 PM
