Idle
Old Aug 18, 2015 | 09:29 PM
ruben24's Avatar
Default Idle
I have an 06 dodge cummins when it idle it has a stutter but only on idle
Old Aug 20, 2015 | 10:49 AM
Jmrobinson's Avatar
When I had a failing injector mine had a lope and somebody said clean your map senator plug-in and pull it out and clean the sensor, it helped with smoke a little bit but it fixed my lope
Old Aug 24, 2015 | 11:35 AM
ruben24's Avatar
I'll try that thanks
Old Sep 10, 2015 | 04:21 AM
11B/11C's Avatar
if that doesnt fix it you could clean it out with some seafoam, or i use atf dexron. the atf works really and i put one qt in a tank to clean. i did that for 3 tanks and its good as new. lots of peope say not to run atf through system but a number of guys do and have had good results with it, 200,000+ miles on stock injectors.
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
Mc Merc
Dec 16, 2014 06:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
