Smoking-wrong kind
Got a guy here in Vermont with a 94.5 f250 7.3ps 4x4 with zf-5 and 180k miles for sale and i've wanted a standard for a while. Says it smokes solid white "like a frieght train" i imagine he means like a steam engine. He seams to think its fractured injector cup or tip. I'm thinking its unburnt fuel. Either un atomized fuel from bad injector, or low compression in a cylinder or two. I want to see if he will let me crank it over to see if it speeds up at all while cranking signifying low compression throught part of the firing order. I dont want to have to rebuild the bottom end if i buy it. What does anybody think? Good buy or Run away?:
if its a ton of white smoke it could be, smell it and you would know. if its an injector it could have messed up the cylinder. but if the rest is in good shape 2k would still be a good deal
