LB7 Crank, No Start
Old Jul 26, 2015 | 03:59 PM
Paladin's Avatar
Default LB7 Crank, No Start
I've been towed home twice now. Pull in on a run and she won't restart.
Finally completely dead. Good crank, no start at all. (New batteries, starter)
First recovery I was able to clear all codes and the I/M, ground the pos battery terminal and it ran better than ever. Threw a P0700 and MIL, said transmission controller...
Second event, pulled in. Went to restart, ran for a sec, then dead. Previous tricks no effect.
This time no codes but the I/M is showing an MIS and CCM "X" again. So trouble somewhere...
Suspect a crank or cam position sensors. Possibly the Fuel Pressure regulator.
Also saw video wear a bad ground was the culprit ...
2001, GMC, 2500HD, 4x4, lift pump, 300K miles. Had it a year no issues.
Automatic transmission gear selector on steering column seems worn...
Open to suggestions...
SkiDooGuy
Sep 9, 2015 05:55 PM
ish1521
Aug 26, 2015 08:42 PM
tmcc14
Apr 21, 2015 03:59 PM
ebg2g
Mar 29, 2015 06:15 PM
musikagod
11
Nov 30, 2014 07:22 AM
