Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
new guy here/ it wont run past half throttle
Old Jul 20, 2015 | 06:41 PM
rusmis91's Avatar
Default new guy here/ it wont run past half throttle
2005 duramax 6.6 LLY w/ 109000 miles, engines never been worked on except oil and fuel filter changes. I have run an hyper tech programmer for several years. Its driven on weekends mostly and vacations. 10 miles after last fill up my truck start bogging down when fuel peddle is pushed past half throttle. Runs fine at idle and cruising speeds, but if you need passing gear and it bogs down and would probably quit if you held it there. Hold it about half and it will only run about 65 mph . Changed fuel filter (ac delco ) still same problem. Took programmer off still same problem. the programmer said it had these codes p0401, p0404 and U1093. Ive worked on trucks before but never diesel engines. Just wondering where to get started. Bought a Haynes Service Manual today.
Thanks
PS Just found this site today, Im very hopefull
Old Jul 21, 2015 | 08:31 AM
Jet A Fuel's Avatar
Looks like a couple EGR codes not sure about the U1093 though.
I am not good with Chevrolet diesels either. But here's what the tech manuals are saying about the codes.
dtc-code-p0401 2005 Chevy.pdf
dtc-code-p0404 2005 chevy.pdf
Old Jul 21, 2015 | 12:07 PM
rusmis91's Avatar
thanks, im gong to try and clean EGR valve
Old Jul 23, 2015 | 12:41 PM
rusmis91's Avatar
Well hooked it up to a better DTC reader and it said that the P1093 code: is loosing fuel rail pressure during power enrichment. Hmmmmm !!!
Old Aug 6, 2015 | 04:44 AM
rusmis91's Avatar
For anybody that's listening or reading the problem i was having was caused from the Fuel pressure relief valve by-passing under heavy load.
Thanks
vin_diesel
Mar 1, 2016 01:43 PM
1stgenswap
Nov 3, 2014 09:45 PM
