2wd/4wd motor mounts different???
Old Jul 17, 2015 | 05:46 PM
jeremiah1's Avatar
Default 2wd/4wd motor mounts different???
I have an 05 4wd 3500 dually chassis. I pulled my motor out of a 2004.5 2wd 3500 dually to put into the 4wd.. swapped harnesses and tried to drop it in but it seems maybe the motor mounts are different between the two?? I have done a lot of cummins engine swaps but never has this issue. Please help any pics would be appreciated.
Old Jul 18, 2015 | 08:50 AM
dangerous1965's Avatar
I've heard of this happening not sure why or for what application but there seem to be a few odd ***** out there! Just use the ones you got from your truck. All the engines are the same it's just the frame mount on a few trucks.
Old Jul 18, 2015 | 01:38 PM
jeremiah1's Avatar
I have the original ones still on the block. (Don't have the ones that were in the 4wd.) I think one side is different.
Old Jul 21, 2015 | 06:32 PM
jeremiah1's Avatar
Got it figured out. The driver side engine mount bracket is different than the 2wd.
