Diesel Work Trucks Discussion of Passenger Diesels used for WORK , Snow Removal , Landscaping , Commuting & Construction Including Tool Boxes and Additional Equipment Attached to your Diesel
Flip out bed steps for easy bed access?
Old Jul 16, 2015 | 03:33 AM
carid's Avatar
FormerVendor
Default Flip out bed steps for easy bed access?
Additional step for your truck's bed is always a plus. If you need to hop and get something really quick from the bed or a tool box a little side mounted flip out step will perfectly do the job.
These static and retractable steps will be perfect for lifted trucks and work trucks.
Here at CARiD we have a wide selection of bed side mounted and rear mounted steps that will definitely make your life easier.
# 1 AMP Research® - BedStep2™ Side Step
- Mounts on either side of the truck bed to the vehicle frame with a small amount of drilling
- Large step pad supports 300 pounds and is large enough for two full-size work boots
AMP Research® - BedStep2 Side Step
# 2 AMP Research® - BedStep™ Bumper Step
- Does not require a trailer hitch because it mounts to vehicle frame member underneath rear bumper
- Large step pad supports 300 pounds and is large enough for two full-size workboots
AMP Research® - BedStep? Bumper Step
# 3 CARR® - Polished Tool Box Flip Step 10
- Sways back and forth and securely locks in both positions (swiveled up and folded down)
- Offered in 3 sizzling finishes: Titanium Silver, Black, and Polished
CARR® - Tool Box Flip Step 10
# 4 CARR® - Work Truck Step (slide in and out)
-Tough aluminum construction with interior steel straps for additional strength
- Able to withstand up to 500 lbs of weight
- Can be either in the open or tucked away position
- When in the out position – provides a solid non-skid step surface for both feet
- Fits industrial, commercial, utility, service, and fire prevention trucks only
CARR® 501050 - Work Truck Step Matte
Check out how it works on this YouTube video:
There's also a huge selection of other helpful bed accessories and parts on CARiD, check them all here.
Which one of those 4 would you choose for your truck?
# 1 AMP Research® - Bed Side Step
# 2 AMP Research® - Bumper Step
Let me know which ones do you like and I will calculate the quote for you!
(Just don't forget to include your Make/model/year, zip and email)
Discounts are available for forum members!
Old Nov 13, 2020 | 09:25 AM
STPETEBLUE's Avatar
Do you have anything that would aid in getting into the bed from the back? I will be putting stake sides on my truck and side access will not be applicable. Please note, the tailgate, on my truck, is 61" from the ground when in the down position.
carid
Diesel Bombers Sponsors
Nov 28, 2018 09:08 AM
carid
Nov 25, 2015 09:01 AM
carid
Oct 24, 2014 03:17 AM
Dual Liner
Show And Tell
May 14, 2012 03:29 PM
