Cranks won't stary
Old Jun 25, 2015 | 09:39 PM
LRSD66's Avatar
Default Cranks won't start
I recently put in a FASS fuel system an upgraded fuel injection pump upgraded fuel injectors and after 3 months the truck will crank and not start it is throwing no codes it will only start with a shot of either would the camshaft sensor cause it to not start?
Old Jun 25, 2015 | 11:54 PM
jkidd's Avatar
Any codes? How many miles do you have on the truck? Were they genuine Bosch injectors? We can test them here if you need to check specs.
Old Jun 26, 2015 | 12:24 AM
LRSD66's Avatar
Old Jun 26, 2015 | 12:25 AM
LRSD66's Avatar
[QUOTE=LRSD66;1094664]265000+ no codes not sure if they are Bosch injectors how much for a set from you guys I have gotten injectors from you before for my previous dodge truck. I would like a set of bigger injectors, these are supposed to be plus 60hp over stock. This is my only vehicle so I can't send theSe in for testing.
Old Jun 26, 2015 | 12:10 PM
Motorops's Avatar
FormerVendor
Have we verified that we are getting fuel supplied to the CP3? If we are getting fuel to the CP3 we can crack a few fuel lines to verify we are getting fuel to go into the cross over tubes to help zero in on where the issue lies.
Old Jun 26, 2015 | 01:46 PM
LRSD66's Avatar
Yes I am getting fuel to the upgraded cp3 from Industrial Injection
Old Jun 26, 2015 | 02:27 PM
LRSD66's Avatar
Old Jun 26, 2015 | 03:06 PM
Motorops's Avatar
FormerVendor
Alright, Have we pulled a couple of the fuel lines going into the head? This way we can verify fuel is getting into the crossover tubes which would tell us it is an injector issue at that point.
Old Jun 26, 2015 | 06:45 PM
LRSD66's Avatar
I have not cracked any Lines to see if there's fuel getting into the injectors because once I hit it with ether it runs it runs fine it just will not start unless I use ether
Rusher48
Jul 2, 2020 08:39 AM
Strangeak
Jun 19, 2015 11:07 AM
tim12valve
Apr 27, 2015 11:42 AM
Cloadkicker
Nov 9, 2014 02:33 PM
Tyler_302
Oct 22, 2014 07:08 PM
