Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
p0620 CODE BATTERY LIGHT ON
Old Jun 24, 2015 | 12:47 PM
Flash123's Avatar
Default p0620 CODE BATTERY LIGHT ON
The battery light came on and shortly after the engine cluster and radio went out, then on, then out. Had batteries and alternator checked, replaced passenger side battery. Alternator checked ok. Still had issue. Replaced alternator, the issue with losing the cluster and radio seems to be resolved but still have battery indicator light on. Also found a wire in passenger side fuse box that was wedged in fuse box (assuming previous owner had something aftermarket hard wired) it was arcing. I removed wire. Code I'm getting is P0620. Anything I should look for first? Anyone had something similar?
Old Jun 25, 2015 | 01:08 PM
gunman41mag's Avatar
Moderator
Is your alternator factory
Old Jun 25, 2015 | 01:54 PM
Moderator
Aftermarket alternator will throw the P0620 code, sometimes the factory alt. with throw the code & will pass when checked. Before changing the alt. check your alternater wiring harness.
Old Jun 25, 2015 | 10:19 PM
Flash123's Avatar
Thanks for the response the alternator I put in came from box store.
Flash123
Jun 24, 2015 01:02 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
yams
Dec 7, 2014 12:51 PM
carid
Dec 4, 2014 05:06 AM
12vlejeune
Nov 19, 2014 05:39 PM
