97 Chevy Diesel
Old Jun 24, 2015 | 12:43 PM
Beeman's Avatar
Default 97 Chevy Diesel
Hello,
I have a 97 Chevy diesel 6.5 turbo that is blowing black smoke and loss of power. I had the injector pump replaced and still no power and the same amount of black smoke. VIN 1GCGK29F9VE198261 I have put over 2500 to get this problem fixed and still no go as my machanic has no idea what is wrong. I did find a vacuum line from the turbo that was leaking and replaced it and still no power and still blowing black smoke. Any help please as I am on my own here with no diesel machanic within 2 hrs of me
Old Jun 24, 2015 | 02:06 PM
kestmic1's Avatar
Turbo has been checked and lines?
Old Jun 24, 2015 | 03:38 PM
Beeman's Avatar
Yes turbo was checked and good so i was told, lines good as well
Old Jun 24, 2015 | 03:42 PM
kestmic1's Avatar
Waste gate selenoid can cause power loss and smoke. That would be next on my list.
Old Jun 24, 2015 | 03:47 PM
kestmic1's Avatar
Also air filter could be clogged
Old Jun 24, 2015 | 03:52 PM
kestmic1's Avatar
Egr solenoid or egr could have failed. I think they had egr that year . Hope some other guys step in with some more info.
Old Jun 25, 2015 | 01:38 PM
Beeman's Avatar
Ok Itied the waste gate shut to test drive and no better. Have a new waste gate sylnoid coming will replace it. Installed a new air filter, will check egr solenoid.
How can I test my turbo
Old Jun 25, 2015 | 03:46 PM
kestmic1's Avatar
shaft play movement side to side in an out of the fins.
Old Jun 25, 2015 | 05:20 PM
kestmic1's Avatar
do you have any leaks of oil? or oil being burnt
Old Jun 26, 2015 | 08:39 AM
Beeman's Avatar
are you meaning around the turbo for the oil leaks?
No there is no oil leaks there but I do have oil leaks which are normal for 197678 miles I would think.
So how do I check for play in the fins, take front off turbo and see if there is play that way
