allison stuck in 3 gear
Old Jun 18, 2015 | 08:01 AM
6.2Lturbo's Avatar
Default allison stuck in 3 gear
driving truck and shift into 3rd and wouldn't go higher or low and no reverse
shut truck off and let it sit for 10-15 minute started back up and now has all gears again
would it be the computer on the side of the transmission
Old Jun 18, 2015 | 02:10 PM
duramaxtuner's Avatar
FormerVendor
That is possible 6.2Lturbo but it sounds more like a failing transmission. Were you WOT when it happened?
Old Jul 26, 2015 | 09:28 PM
6.2Lturbo's Avatar
I talked to some local shops and they said it's the computer on the transmission I have now replaced it and still locks the transmission in a gear shut truck off sit for 30 seconds start it back up and everything works again
Old Aug 7, 2015 | 09:12 PM
Mikie1986's Avatar
I had the same issue it was just the sensor on the side of the transmission I replaced it for $140 and she's running great again !
Old Aug 15, 2015 | 01:25 PM
2004LB7's Avatar
3rd gear is the default gear the transmission goes into when in limp mode. There are many reasons for the transmission going into limp mode. What was it/you doing just before it happened?
Reading the transmission code could shed some light on the cause. Unfortunately most code readers won't read transmission codes. You may have to take it to the dealer or allison shop to find out
corksil
Aug 2, 2015 10:19 PM
Hotrodd_67
Jun 22, 2015 09:50 PM
Jun 4, 2015 09:30 PM
aoutlaw95
Mar 3, 2015 09:02 PM
rtbcoop
Nov 29, 2014 11:33 PM
