Help. 6.7 won't start
Old Jun 15, 2015 | 09:03 PM
1ton butcher's Avatar
Default Help. 6.7 won't start
So this is a brain teaser. Need some out side help. Truck has full deletes and has h&s XRT pro. Guy had injector #2 swapped and truck has had troubles since. Dealer replaced injection pump and fuel is getting to injectors. Truck tries to start with just a sputter then quits. Will keep cranking but won't try to run at all. Unless you cycle key. I returned ECM to stock searching for codes and none popping other than the norm for deletes. Tried flashing ECM and result is same. Need ideas. Truck also has auto start but owner says its disabled.
Strangeak
Jun 19, 2015 11:07 AM
cjgregory
Mar 31, 2015 01:45 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
drivecumminsridered
Nov 13, 2014 06:31 PM
