03 Gauges going nuts
Old Jun 4, 2015 | 10:42 AM
flainn's Avatar
Default 03 Gauges going nuts
Hello,
My instrument cluster is going crazy on my 03 Ram 2500, 5.9 HO, NV5600 4x4.
The check engine light comes on randomly for a second or two, then the volts/oil pressure/coolant temperature gauges will all quickly drop to zero, then slowly sweep back to where they were before -- and then the check engine light turns off again.
Sometimes, also, the fuel gauge (independently of the other gauges) will drop to zero and the fuel light will come on, and a chime sounds. Then, usually but not always, the gauge will sweep back to where it was and the fuel light will go off. When the fuel light is on, the AC compressor cuts out and will only come back on when the gauge sweeps back and turns off the fuel light. Also, when this happens my overhead computer blanks out (just dashes for the average fuel economy and distance to empty).
Also, sometimes both the tachometer and speedometer will drop to zero and then sweep back to where they were.
I also get blinking ABS and airbag lights randomly.
When we recently drove to Tucson from Albuquerque, this all happened over and over for hours. Then eventually the entire gauge cluster went dead (no gauges at all). I pulled over and disconnected both batteries for ten minutes, and that got them working again, but that just started a new cycle of the gauges going crazy. I ended up having to use my phone's GPS to figure out how fast I was going.
These behaviors seem to have no relationship to temperature (has happened on very cold mornings before the engine is warmed up, and also happens on hot (90+) afternoons with the engine at full operating temperature). The behavior is completely random, as far as I can tell. It happens more frequently when driving at high speed, but it also happens sometimes when the truck is sitting at a stop light. This morning it started happening immediately after starting the engine, after the truck had been sitting for more than twelve hours.
Here's the troubleshooting I've done:
I did a test of the instrument cluster (hold the odometer reset button while turning the key to On) and all lights illuminate and the gauges sweep just fine.
I removed the gauge cluster from the dash and used electronic contact cleaner on the male and female end of its three connectors. This had no effect.
Any suggestions where to go from here? I'm pretty certain there's nothing wrong with the gauge cluster itself. Would these problems be caused by a bad ground somewhere, or does it seem more likely my ECM or PCM are faulty?
Old Jun 4, 2015 | 01:16 PM
Jet A Fuel's Avatar
Default Schematics
Here are some schematics to help you trace the problem.
I see a common denominator in the integrated power module fuse 28 hot in run. and also the PTC 2 at the junction block.
Sounds to me like your loosing power or ground intermittently like if you were shutting off the key and turning it back which makes the gauges all swing and the warning lights light up.
Instrument cluster diagram :03 dodge.pdf
Overhead console diagram : 03 dodge 1.pdf
Old Jun 4, 2015 | 02:36 PM
flainn's Avatar
*Very* helpful. Thank you.
Old Apr 8, 2016 | 04:28 PM
flainn's Avatar
This turned out to be a ground strap that had rubbed a hole in the main harness that runs along side the transmission. Every once in a while the ground strap would contact the J1850 sensor bus wire and make the gauges go crazy. Very hard to find unless you have a lift and a pit to stand in!
Old Oct 11, 2024 | 10:41 PM
Duramaxdaddy's Avatar
Could you elaborate on where exactly the ground strap is, I'm having this exactly same issue but I can't seem to find any ground on the Trans at all
Old Oct 12, 2024 | 09:39 AM
flainn's Avatar
I didn't get any first-hand experience; I took the truck to the best diesel shop in Albuquerque and the guy found the issue and told me what it was.
It's been almost a decade now, but I vaguely remember him saying the ground strap was between the transmission itself and the truck body, and (maybe) located on the top of the transmission. Very hard to get to or even see unless you can put the truck up high on a lift.
Good luck! I lost this truck in my divorce (had to sell it to buy the ex wife a car) and now I'm driving a 2004 Duramax.
moparisthebest
Price Quote - Request A Price
Oct 21, 2015 07:31 PM
Powerstroke36
Sep 6, 2015 02:41 PM
May 1, 2015 08:10 AM
Justin82
Apr 1, 2015 02:22 PM
carid
Diesel Bombers Sponsors
Dec 9, 2014 03:58 AM
