Exhaust cut off then hi idle issue
Old May 26, 2015 | 05:11 PM
Poorboyljl's Avatar
Default Exhaust cut off then hi idle issue
Okay I have a stock ram 2500 2011 and had took off the cats and put straight pipe, well it made my turbo spool really outta wack, and now it always hi idles, so I took to a place they said get it back on, took it back and put stock back on, all my dash lights went away, but still hi idles? What could be issue? Also the exhaust had double pipes in down pipe so I welded it fast to the other pipe? Was tht bad?
Old May 28, 2015 | 08:34 AM
Motorops's Avatar
FormerVendor
When you took the stock exhaust off did you have a tuner to shut off the codes to eliminate the DPF system?
Old Jun 6, 2015 | 09:59 AM
El Pozzinator's Avatar
did you weld with everything on the truck? that's a lot of juice to push through all the computers... did some low-power tack welding on my 97 a while back, and followed advice to disconnect and remove the batteries. turns out i shoulda pulled the ECM as well. tack-welding to the body cooked my ECM, even though it was on the opposite side of the engine compartment, bolted to the firewall.
JoeyMiR
9
Feb 3, 2018 10:05 PM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
