04.5 5.9 CUMMINS LIGHT BLACK SMOKE AT IDLE
Old May 14, 2015 | 11:22 AM
ryank 199's Avatar
Default 04.5 5.9 CUMMINS LIGHT BLACK SMOKE AT IDLE
i recently bought this truck it sat for about a year the lady used it on her farm its got about 171,xxx miles on it. b4 i ever started the truck i did a oil changed and replaced all the filters and pulled the common rail off to make sure there wasn't any rust or its in it. everything looked good. so then i threw my new batteries on it and cranked her up. trucked idled good sounded alright. so i took it for a ride and i noticed it was black smoking alot more than it should for being bone stock. So i figured it might be the old diesel that was in it so i put 10 gallons in it and some POWER SERVICE DIESEL KLEEN + CETANE BOOST as well. from there i went and drove it again truck continued to smoke like b4 but this time when i got to the house the truck was smoking enough at idle that you could see it fairly good. A very knowledgeable friend of mine said it was more than likely a leaking injector. I don't know if the lady i bought it from drove it with it leaking or not so he said to pull the injectors and do a compression test on it to see if she washed out a cylinder.
so i guess where im going with this is if it is the injectors wheres the best place to get the compression test adapter for a 24v. and also what psi should the cylinders be reading. and any other input or help would be great.
thanks
Attached Thumbnails 04.5 5.9 CUMMINS LIGHT BLACK SMOKE AT IDLE-20150509_185219.jpg
Old May 14, 2015 | 06:41 PM
j johnson's Avatar
any diesel needs at least 300 psi to start...compression tester you can get from cornwell tools or harbor freight...scott
JoeyMiR
9
Feb 3, 2018 10:05 PM
Jmrobinson
11
Aug 21, 2015 09:54 PM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
carid
Apr 15, 2015 07:29 AM
sootman
Jan 22, 2015 05:12 PM
